Originally Posted by
Sport_Pilot
FAA says it is any device designed to fly in the air, ballons and model airplanes are aircraft to them. So a football does fly though the air and is an aircraft. If you don't agree then maybe the FAA should instead require Frisbee's to be registered. I bet someone could attach a radio to one as well.
From the FAA site - definition of aircraft.
A device that is used or intended to be used for flight in the air.
I would be interested to see if there is a precedent anywhere in the world where a court has declared a football an aircraft...
Next thing you know the FAA will register all football players and the footballs will require N numbers.
