RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 01-04-2016 | 06:38 AM
  #2839
rgburrill's Avatar
rgburrill
Originally Posted by HoundDog
Originally Posted by Sport_Pilot
Then again you can strap a bomb to it and kick it into a crowd! And it meets the definition of aircraft!
Probably the only one that counts the FAA's.
Historically, the
FAA has considered model aircraft to be aircraft that fall within thestatutory and regulatory definitions of an aircraft, as they are contrivances or devices thatare “invented, used, or designed to navigate, or fly in, the air.”
I'd say that a football having a pointy end on each end and it is contrivances or devices that are “invented, used, or designed to navigate, or fly in, the air.” indeed meets the FAA's definitions of an aircraft, Of course that may only be in the Northern Hemisphere. Where the FAA makes up it's own definitions.
By your stupid analogy a bullet also flies in the air. It's ballistic trajectory, geez.
