RCU Forums - View Single Post - Pull Pull Controls
Old 10-20-2003 | 04:07 PM
JimTrainor
Default RE: Pull Pull Controls
The non-straight cable runs also made me wonder.
The value of adding positive Ackerman, IMO, is simple to ensure you don't inadvertantly end up with negative.... which would be a bad thing.
If you're careful with the whole setup there is no reason I can see why you'd end up with negative. If your a bit sloppy (just a bit) I can see how the non-pulling wire could tighten up and cause problems.
