RCU Forums - View Single Post - Amadeus
Thread: Amadeus
Old 01-06-2016 | 07:31 PM
  #112
RodneyFord's Avatar
RodneyFord
A break from work means more work on the Amadeus. Can also travel up to Ewan's to collect the Rohacel foam so I can mold the fuselage.
Sorted out the wing plan form. Wing area is 1067 sq. in. Foils are S8035 modified 12.5% root 11.5% tip. The trailing edges are slightly thickened about 4.5mm. S8035 has the high point further forwards than the commonly used NACA 63 series foils. Joe Wurts and prof. Selig think S8035 should be a good aerobatics aifoil. Tail is SD8020 as usual.
