The FAA's response: “The FAA disagrees with the comments asserting that the registration of model aircraft is prohibited by section 336 of Public Law 112-95. While section 336 bars the FAA from promulgating new rules or regulations that apply only to model aircraft, the prohibition against future rulemaking is not a complete bar on rulemaking and does not exempt model aircraft from complying with existing statutory and regulatory requirements. As previously addressed, Public Law 112-95 identifies model aircraft as aircraft and as such, the existing statutory aircraft registration requirements implemented by part 47 apply.
This action simply provides a burden-relieving alternative that sUAS owners may use for aircraft registration. Model aircraft operated under section 336 as well as other small unmanned aircraft are not required to use the provisions of part 48. Owners of such aircraft have the option to comply with the existing requirements in part 47 that govern aircraft registration or may opt to use the new streamlined, web-based system in part 48.”
