Originally Posted by
bluelevel
Is there a reason why everybody moves the thrust tube so far backwards that it sits flush with the fiberglass tailcone? Wouldn't it be advised to move the turbine and thrust tube closer to the tank and slightly cut the fiberglass tailcone instead of adding useless nose weight?
Hey Thomas! Didn't know you bought one! I looked at mine today to remember the mounting. I don't see any reason that you can't do it that way. You will only get about an extra inch forward. I am sure it will help eliminate some nose weight. Let me know when you are going to maiden, and I will come out to watch.
