Originally Posted by
flyinwalenda
That looks like it has been around. That is an older surpass engine and if it's in running condition it may be worth $30.00 toward your conversion. Does the wing have ailerons ? I see a servo mounted on it's side in the front....not sure from the pics what that would be for.
If you want to convert it to electric you would need at least a Power 46 motor(or equivalent ) a 60amp ESC and a 4 or 5cell lipo.
If you have the equipment lying around I would do it. If you have to buy it I would think twice.
I don't mind buying brushless stuff because i can always use it in other projects. Yeah shes old, pretty cool tho. Mostly mono kote and balsa wood. No ailerons, should be interesting the first few flights!! Anyone wanna buy this motor! haha
blvdbuzzard
you are correct, the side door can come off and that whole velcro piece moves. pretty neat. Thanks for the links, gives me a better idea.
flyinwalenda
Suppose it could be a candy-drop box door release.
