RCU Forums - View Single Post - DX-18 Elevon travel adjust
Old 01-11-2016 | 06:32 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by rcjetsaok
I can't figure out how to set the elevator and aileron full travel values and get them to be the same on both sides... If you go into the aileron travel it sets one side correctly but not the other, and if you go into the elevator travel is sets the other side. Which is fine, but the elevator both sides have to be more than the aileron both sides... I'm confusing myself just trying to explain it... I hate to think how confused you are trying to understand what I'm saying..
I need 40mm elevator and 30mm aileron... How do I make that happen??? The radio is set to Elevon, the directions of travel are correct. I just can't get my throws set.. It's got to be easier than I am making it...
Danno
I don't have my DX18 anymore but if it doesn't have an actual menu that allows you to adjust the mixing values of Aileron & Elevator about all you can do is adjust for equal up/down on RAL and LAL using the servo travel adjust settings and then use aileron dual rates to set aileron travel and elevator dual rates to adjust elevator travel.
Hopefully someone will have a better answer for you..
