Originally Posted by
turbofixer
As RC Pilot of any kind you should be thankful the AMA does anything. like it or not with out it the FAA would run us all over.
I am, right up until the point they start using sections of the law to require membership. If they're really so altruistic about model aviation as they contend, ALL model aviation, then why require you to be a member just so you can fly a "model aircraft" under PL112-95 section 336 (a)(3)?
