RCU Forums - View Single Post - DX-18 Elevon travel adjust
Old 01-11-2016 | 04:22 PM
rcjetsaok's Avatar
rcjetsaok
My Feedback: (7)
I think I have figured it out.. At least the result is what I'm looking for. I set the travel adjust on both elevons to the amount for full up elevator. Then I went to dual rate and lowered the aileron value to the amout needed.. The aileron dual rate switch is in the usual location with 3 positions. I can actually set different rates and then after getting it the way I want, set all three the same or move it to a less obscure switch. If I inhibit the switch then the values I selected go away and goes to full travel like the elevator. This will work fine. Thanks for the help, and if there is a different way to do it, I'm all ears !!!
Cheers,
Dan
