That's a real Franken engine then.
Guess the header and the larger carb all add up. Any websites most likely cite the weight including muffler, you can't trust what you read on the web...
If you have the KB .18 carb, it is has a much larger bore compared to the stock carb. I've had problems with the fuel draw even on the KB engines. Here is a comparison of the two carbs;
