Originally Posted by
soarrich
50 pounds, that's optimistic!
I think you'll get 10-12 pounds of static thrust. Flying you'll be nearer 15 pounds though.
Where did you come up W/50# of thrust?
50# /22kg is the weight capacity of the scale.
The physical weight of the aircraft will be 15# W/fuel!
As far as static thrust, it should approach 19# at 8150RPM W/an 18x8.
