RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 01-20-2016 | 06:06 PM
  #1702
Pretendpilot
Originally Posted by chorner
.... and if you really care about your engine, add a small amount of RedLine Break-in Additive to your mix. It contains zinc, and phosphates that greatly enhance wear charcateristics and works like having castor oil in that it thoroughly coats and 'sticks' to the mating components and creates a very good boundary layer between the two parts - much more so than straight 2 stroke sythentic can & will alone. Use it at least until you use up the first bottle of it, then maybe once in a while thereafter. Kind of like when you buy a new car - and you would traditionally run it on a castor based oil, then switch to synthetic after a certain mileage.
wouldn't this be bad for break-in? I always heard it is better to have an oil that is less effective to beak-in, so the parts WOULD wear together?
btw, what RPM does the 777 like to run at? is it better to load it to 4k or to 5k or?
