I usually start with the basics, like making sure the batteries are new. If you only have one tank it's a lot harder to troubleshoot stuff. With two you can swap parts back and forth to find where the problem lies. With a no start situation it could be either the TX or the MFU. The only way I know to check is to try a different TX or MFU and see if it makes a difference. Where are you?
