RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 01-26-2016 | 02:41 PM
  #1709
jspauld2
Originally Posted by Pete S-RCU
OK, it's a 34x14 prop, my mistake.
Although they sent an ignition sensor module and wire, it's been run at the factory and so I'm thinking it's not needed.
I think the ignition sensor is inside the rear of the engine where the ignition unit is mounted.
How would I hookup a telemetry tach to this engine, I have a Spectrum TM1000 unit?
I'm using one on my Saito FG57T twin and it just hooks to the ignition module, works good.
Pete,
I don't believe there are any extra wires included with the engine.
As for the telemetry, unfortunately there is no 'plug and play' option out there. The built-in telemetry feedback is unique to RCExl style ignitions like what's on the smaller gas engines by Evolution (Saito, Zenoah, and others as well). You would need to use a universal sensor and find a way to measure the RPM from the crank
Hope this helps.
Jimmy
