It does not have a roller bearing rod. But the MFG says 25/1 and I have had it and flown it for several years with that mixture My concern was the plug on that mixture.
If you are curious about the NGH engines go to agaperacing.com. I think they are the best small Chinese engines.
I tried it and never got a pop out of it. I will try again tomorrow. I will run it first on ignition to warm it up then switch it to the gas-glow plug and try it again
Reason: update
