Originally Posted by
Pete S-RCU
The issue is getting a signal to the tach, the coil 'might' provide it?
It may also have to be amplified to a usable level?
If so, I could possibly build a little amp with a few op-amps.
Something to think about.
That's not a bad idea. I do not know the specifics needed for the input on the TM1000, and you may fry one or two along the way, but I think the theory might work. As long as you are careful with what you are feeding the TM1000 this might work. I'm definitely not an electronics expert, but it seems well thought out.
