RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 01-27-2016 | 08:47 AM
  #1715
Pete S-RCU
Originally Posted by jspauld2
That's not a bad idea. I do not know the specifics needed for the input on the TM1000, and you may fry one or two along the way, but I think the theory might work. As long as you are careful with what you are feeding the TM1000 this might work. I'm definitely not an electronics expert, but it seems well thought out.
I have a Eurcoupe with a Saito 57cc twin in it.
It has the CH igniotion system with a rpm output that works with a digital tach, or the TM1000 telemtry module.
Won't work with both at the same time however, probably the input impedance is too low and the signal gets dragged down too low.
Will have to get my scope out and measure the signal to see what I need.
Will have to wait till the weather warms up a bit before I can run the Saito and do my research.
S/B fun.
