On the WM covering you do need to go over it with a iron and then seal up the edges. These planes don't take much elevator, so use book suggestions. When setting it up neutral is with a little down elevator. If you set it level it will climb a lot on you when flying. When you go to take off you need to hold up elevator and once off the ground slowly relax the elevator.
