Originally Posted by
Sport_Pilot
At 120 MPH the Drone did not fly over the chopper the chopper flew under the drone ... If they saw it why did they continue on the course. Would it be an incident if it were an 8' wing span bird? If I were flying a piper cub at what ever altitude they were at whose fault is it if they come up from any where with in `08 degrees on my 6. ... The technology is coming ADS-B but can we afford it.
All aircraft except those on an FR flight Plan and inIMC must see and avoid... if R/C TOY's are to be treated like airplanes then they have the same rights as other users of the NAS.
[TABLE="width: 100%"]
[TR]
[TD="width: 100%, colspan: 2"]
Part 91 GENERAL OPERATING AND FLIGHT RULES
[/TD]
[/TR]
[TR]
[TD="width: 50%"]Subpart B--Flight Rules[/TD]
[TD="width: 50%"]
General
[/TD]
[/TR]
[/TABLE]
Sec. 91.113
Right-of-way rules: Except water operations.
(a) Inapplicability. This section does not apply to the operation of an aircraft on water.
(b) General. When weather conditions permit, regardless of whether an operation is conducted under instrument flight rules or visual flight rules, vigilance shall be maintained by each person operating an aircraft so as to see and avoid other aircraft. When a rule of this section gives another aircraft the right-of-way, the pilot shall give way to that aircraft and may not pass over, under, or ahead of it unless well clear.
(c) In distress. An aircraft in distress has the right-of-way over all other air traffic.
(d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories--
(1) A balloon has the right-of-way over any other category of aircraft;
[(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.]
However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other head-on, or nearly so, each pilot of each aircraft shall alter course to the right.
(f) Overtaking. Each aircraft that is being overtaken has the right-of-way and each pilot of an overtaking aircraft shall alter course to the right to pass well clear.
(g) Landing. Aircraft, while on final approach to land or while landing, have the right-of-way over other aircraft in flight or operating on the surface, except that they shall not take advantage of this rule to force an aircraft off the runway surface which has already landed and is attempting to
make way for an aircraft on final approach. When two or more aircraft are approaching an airport for the purpose of landing, the aircraft at the lower altitude has the right-of-way, but it shall not take advantage of this rule to cut in front of another which is on final approach to land or to overtake
that aircraft.
Amdt. 91-282, Eff. 9/1/2004
Comments
