Originally Posted by HoundDog
Where's the GD URL PLEASE....
Originally Posted by Silent-AV8R
There was never any mention of 400 foot anything in Section 336 of P.L. 112-95. Nor is it in the proposed Part 101.41 governing model aircraft operations. The one and only place 400 feet is officially mentioned is in AC 91-57A, where it is referred to as a "best practice". The 400 foot guideline in the registration process carries no regulatory or legal weight.
Silent-AV8R
Less than 1 second because UR wrong
The URL on
proposed Part 101.41 governing model aircraft operations. and what part U are specifically are referring to.
This is what i get when I google (Part 101.41) is it any one of these?
Search Results
- [PDF]AMA_sUASNPRM_Comments.pdf - Academy of Model ...
www.modelaircraft.org/gov/AMA_sUASNPRM_Comments.pdf
May 1, 2012 - Operation and Certification of Small UnmannedAircraft Systems ... aircraft (model aircraft) users, the Academy of Model Aeronautics (AMA) .... part does not apply to any aircraft or vehicle governed by part 103 of this chapter,part 107 ... However, the new § 101.41 Subpart E for model aircraft was not added ...
Operation and Certification of Small Unmanned Aircraft ...
www.regulations.gov/#!documentDetail;D=FAA-2015...
Regulations.gov
Feb 23, 2015 - Lastly, the proposed rule would prohibit model aircraft from endangering ... B. Current Statutory and Regulatory Structure Governing Small UAS .... As part of its ongoing efforts to integrate UAS operations in the NAS in accordance ...... Add subpart E, consisting of §§ 101.41 and 101.43, to read as follows: ...
[PDF]Notice of Proposed Rulemaking (NPRM) - Federal Aviation ...
https://www.faa.gov/.../2120-AJ60_NPR...
Federal Aviation Administration
Feb 15, 2015 - RIN 2120–AJ60. Operation and Certification of Small Unmanned Aircraft Systems .... B. Current Statutory and Regulatory Structure Governing Small UAS. C. Integrating ....Specifically, the FAA is proposing to add a new part 107 to Title 14 Code of. Federal .... Proposed rule would not apply to model aircraft.You've visited this page 3 times. Last visit: 1/23/16
FAA Proposed Rules Comments | DJI Phantom Forum - PhantomPilots.com
www.phantompilots.com › General Forums › News
Mar 18, 2015 - There may be few FAA rules regulating hobby flight, but please use common sense. If your flight ... That being endangering the NAS or operating in a careless or reckless manner. Simply ... Pages 46 - 48 provide a discussion of howmodel aircraft are to be handled. Part 101.41 makes this even more clear:.
FAA Announces Rules for Aircraft Registration Process - Page 23 ...
www.flyinggiants.com/forums/showthread.php?t=190849&page=23
Dec 14, 2015 - Page 23-Article FAA Announces Rules forAircraft Registration ... Look at Section 336 or Part 101.41(proposed) which will govern model aircraft. ... good operatingpractice" , namely being above the FAA suggested 400'.
Are there any Nationwide CBO's other then the AMA? - Page 2
www.rcuniverse.com/.../11613600-there-any-nationwide-cbos-other-the...
Feb 23, 2015 - Neither their interpretation or the newly proposedPart 101 mention AC ... Subpart E – Special Rule for Model Aircraft§ 101.41. Applicability.This subpart prescribes the rulesgoverning the operation of a model aircraft that ...
[PDF]Filed electronically - RCGroups.com
www.rcgroups.com/forums/showatt.php?attachmentid=7802725&d...
Apr 24, 2015 - Specifically, proposed 14 CFR § 101.41: prescribes the rules governing the operation of a model aircraft that meets all of the ... In our view, the FAA was free simply to exclude from proposed part 107 (its small UAS rule).
[PDF]JUNE 2015_PG_1.PUB - Sun Valley Fliers
sunvalleyfliers.com/legacy/news_archives/2015/slo_roll_jun2015.pdf
Pablo Montoya's love of model aircraft, you can read an .....DOT / Federal Aviation Administration – Docket FAA-2015-0150Operation and ... or vehicle governed by part 103 of this chapter, part 107 of this chapter, ... 101.41 Applicability.
[PDF]unmanned balloons, kites, amateur rockets, model aircraft ...
https://gaca.gov.sa/.../Satellite?...
General Authority of Civil Aviation
101.41 Applicability. .... (a) This part prescribes rules governingthe operation of the following in the ... (5) Any model aircraft as defined in GACAR Part 1, and.
[PDF]Federal Aviation Administration Summary of the ... - AGRiP
www.agrip.org/.../Wiley%20Rein%...Association of Governmental Risk Pools
Feb 16, 2015 - authority in part 101 by prohibiting model aircraft operators .... With regard to privacy concerns regardingUAS operations, the FAA notes that, ...
[HR][/HR]
