RCU Forums - View Single Post - ETO Gearboxes!
Thread: ETO Gearboxes!
Old 02-06-2016 | 10:40 AM
  #33
sevoblast
Originally Posted by MAUS45
You are correct, I fear that once I get a set for the Tiger II, then the Panther and the Tiger I will need a set!!! I do not mind drilling two extra holes in the lower hull of the Tiger II. I really want a bullet proof set of gear boxes for the Tiger II. I have metal tracks so the torque is important to be able to creep at scale speed.
Maus45, with these units you will be able to creep through ankle deep red clay mud if you desire with no problems. The two extra holes are easy to locate, it is explained in the instructions with photos. I do recommend that you have extra track links on hand. The units are so strong that unlike in years past where if you ingested a stone or other obstruction in your track system you would chew up expensive gears, with my system you will break a track link. Been there done that.
