Well checked the CG today with my new gen3 xicoy balancer and it seems much more accurate and is lining up with my cg that I already did the old way. Mine showed just tail heavy, needed about 0.23 lbs to make it level but since im going with a little further aft CG this should be spot on since the measurements are for the book CG final weight is 40.5 lbs with UAT full tank empty. So a bit heavier than I wanted but thats the P200 weight. Planning to maiden it tomorrow so happy about that.
