RCU Forums - View Single Post - GP CHRISTEN EAGLE
Old 10-21-2003 | 10:22 AM
  #53
Texas 3D's Avatar
Texas 3D
My Feedback: (16)
Default RE: GP CHRISTEN EAGLE
ORIGINAL: rvpinto
Here is another idea for the airleron servos. I have have this set up in my 40% Pitts and it is beautiful with no exposed wires. Install the top wing servos and instead of running the leads to the inside of the wing, cut a hole where the interplane strut is and run the lead down the inside of the strut, install a standard y connector in the bottom wing. Plug both servos into the Y and have the one lead coming out of the bottom wing center. From there you can use a Y splitter and use one channel for airlerons or mix them in on two channels. Very clean, with no exposed wires. People will wonder how you did it.
Sounds like a neat solution and I like the idea of being hidden, but how long are your servo extensions? I am always afraid of going with to long extensions.
