TopRCModel
I first heard of them from Mike at F3AUnlimited when they introduced their 2m Caelus composite pattern plane for $999 (amazing price for a composite 2m, compared to Oxai and BJCraft)
The quality of construction and flying were very good, the only negative was that they were just a bit heavy and need attention to hit 5Kg flight weight max.
They now have a Cougar for $995
http://www.f3aunlimited.com/f9f-cougar-b
Specifications
Length: 1803mm/71in
Wing Span: 1562mm/61.5in
Ducted Fan: 120mm
Turbine: 6kg turbine
Radio: Min. 7 Servos required
Descriptions
1. Full composite construction.
2. All surface prepainted,decals applied and clear coated
3. Scale cockpit included.
4. Detachable main wing and tailplane & vertical fin for easy transportation;
5. Removable hatch on fuselage for easy access into the plane and change accessories;
6. Functional flaps for smooth landing.
7. High quality CNC Alu push rod included
8. More than 95% assembled complete in factory.
9. Tail tube and fuel tank included.
And also 2 sport jets, the Odyssey and Aspire...still trying to find details on those.
