Rex, I just got off the phone with John, it may be the kero plug valve stuck open since fuel runs out both lines when I purge the main fuel line. If the valve is being opened by the ecu wrong then it's probably the ecu. Hopefully the new valve will fix it, probably going to be next month before I can get the maiden done.
