RCU Forums - View Single Post - Engine identification
Old 02-08-2016 | 07:42 AM
wcmorrison
The engine is probably out of production and thus no readily available manuals. But almost any glow, 2 stroke, engine manual will do. Since you will not be able to get parts, you do not need that kind of info any more. The running, care and feeding of a 2 stroke glow engine is just about the same for all, the major difference would be in type of carb, whether it is a two needle or a base bleed type. If it has ball bearings, the ball bearing dealers will know the size of the bearings if you need replacements. Otherwise, that's about all there is to it.
