Originally Posted by
izzy
SB2261
below is the link to the servo - zero play - but you need to rebuild the housing
also make sure to change the geometry such that the horn will be 90 degrees to the hinge line
skymaster glued the servo mounts wrong, and if you keep it that way , you need to use ball joints to make up for the mistake
( ask me how i know - i built mine, and fixed the others that i built for friends )
http://www.savoxusa.com/product_p/savsb2261mg.htm
izzy , thanks for the info. can you expand on what you mean by they glued the servo mounts wrong? my kit is about a year old. do you think they might have corrected the issue after yours was built? WB_1 ..... any chance you might have some pics of the work?
