RCU Forums - View Single Post - How do I rescue a drone from a big tree?
Old 02-09-2016 | 10:26 AM
daydream believer
Buy a cheap fishing pole from a local tackle shop.
You can buy a 9 metre one for £ 22-00 They do them up to 18 metres but they will be expensive
Then fit a hook made with a coat hanger in the end
The pole is handy as it will fold to 3 feet lengths. get one where the outer ends slide inside the handle end . I cannot recall if that is described as "put over" or "put in" but a tackle shop will tell you
Plus if you do not get it down you can take up fishing there is a lake nearby you can use
