RCU Forums - View Single Post - Monocoat Backing Removal Tips Anyone??
Old 10-21-2003 | 11:21 AM
runover1's Avatar
runover1
My Feedback: (10)
Default RE: Monocoat Backing Removal Tips Anyone??
I find the sharp x-acto knife trick to work great especially at an angle. I have had some very small graphics at times, and this seems to work best. Try it at an angle. Also with small stuff, I find that rubbing a little acetone on a cloth over the area you are applying to helps greatly. This is for monokote over monokote. But I stick with the knife trick on small pieces. At a good angle, you should not poke through the covering.
Good Luck![8D]
Just to be sure we are on the right page, I stick the knife through the backing at a slight angle and it lifts the backing off of the covering. I do not try and find the edge, you will be there forever.
ID:	69069   Click image for larger version
ID:	69070   Click image for larger version
