RCU Forums - View Single Post - Connector Mouldings by Digitech
Old 02-11-2016 | 05:42 AM
digitech
My Feedback: (10)
Default Connector Mouldings by Digitech
Hi
maybe something interesting for you guys.
always having to solder your connectors and having them look bad or poor isolated?
with these mouldings and a Glue gun you can make your own Isolation around Multiplex , XT60 XT90 male of female.
you just take your soldered cable AND CONNECTOR put it inside the moulding , add Hot Glue and done!
The Mould opens by fastening 2 screws that will force open the mould , no no screwdrivers or hard pulling is needed.
we have special Black cartridges that are a bit harder then the standard Transparent stuff.
For each Connector type you need a Moulding.
you need also a good Glue Gun with Good warmup time and some volume (12mm Cartridges)
we have
MPX does both male and female (normal 3mm Leads)
MPX-JC (Jetcat batterys) has a Larger cable channel for the A123 (4mmx8mm)
XT60 does Both male and female.
XT90 does both male and female
XT90 XL Does bopth male and female and has a extra wide cable channel (12x4mm)
all is made in house on our own Mill , Alluminium 7075/ Pins and screws are Stainless steel.
milled to perfection ...
Best Regards
Sandor Kruise
ID:	2146539   Click image for larger version
ID:	2146540   Click image for larger version
ID:	2146541   Click image for larger version
ID:	2146542   Click image for larger version
ID:	2146543   Click image for larger version
ID:	2146544   Click image for larger version
