volcano exp pro problems
I have a volcano exp pro brushless that just started a problem when you try and take off it chatters a few times and wont move,sometimes you can give it a little shove and it will run fine until you stop then chatters and wont move again.If you hold it up off the ground it will run just fine.
I changed the spur and motor gear and looked at the rear gears they look good,but still wont move???????????
