Hi Jeff,
What size life battery (MAH) are you using on the gear? I've been experiencing some issues with mine and just had a 1100mah life pack made. I was told upping the voltage should solve my problems. I have the xicoy lg13c controller. I've cycled the gear many times in a flight and even after three flights It seems to only use a few hundred mah. Does this match what your seeing?
