Originally Posted by
Mr Cox
That depends on the MAS model, the older ones have a beefier blade than the newer ones. The zinger ones are even worse though, which could explain the lower numbers in the review.
I wouldn't focus too much on the detailed numbers from one end of the world to the other. They both seem to make about the same power as the old and trusted Veco .19 RC on that prop, so certainly good enough in order to fly something.
In practice, I'd be putting a big prop on it. I think a 9x5 is the minimum prop K&B recommended, but I'd be going for a 10x5-10x6. These things excel on big lumber. I tried a 13x4W and got in the mid 6k range on diesel. Just under 9k on an 11x6 IIRC.
