RE: Pitch Coupling Mixing - Leave it on ?
I leave my mixes on all the time. I usually run a rudder - elevator mix, a rudder - aileron mix, and a throttle - elevator point mix. I've found that if you hit the rudder in knife edge and the plane pitches to the belly, it also usually pitches to the belly when you hit the rudder in level flight.
