Originally Posted by
NorfolkSouthern
I don't think there will be a way to differentiate between a traditional RC plane and a drone. Both use a transmitter and receiver, and both can be equipped with a camera. And they can have the same range. A quad would be safer in that usually, they have software that will cause them to land if they lose contact with the transmitter. That is not the case with a traditional RC plane. So one is not necessarily safer than the other. For those who feel the government can't register all the kit-built models. You are right. However, the government CAN require the registration of ANY new receiver, and even go as far as requiring a background check just as if it were a firearm. The ATF does the same with guns. You can buy a new trigger assembly for a Ruger 10/22, a new barrel, or any other part you want. But the lower receiver is the serial-numbered part, which cannot be transferred by a gun dealer without a background check and the proper paper work. Registration of the receiver on a model plane would cause that to be the serial-numbered part, thus assigning that serial number to which ever model aircraft the receiver goes into.
Don't discount the long arm of the U.S. government. It has a long reach!
And don't forget, your private information is now a public record. and to make matters even worse you gave them your credit card number.
We all know from recent event how secure their date base's are...
This is wrong on so many fronts.
