RCU Forums - View Single Post - Need Help with P-70 fail safe programming
Old 02-18-2016 | 06:04 PM
Thud_Driver's Avatar
Thud_Driver
You're close. Attached is a JetCat manual.
You need to decide whether to use the Aux Channel, most of us don't and typically use single channel mode.
Look that up and do as you want. I do the following for failsafe & throttle range:
Set Low Throttle end point to -150% and bind. Reset Low Throttle end point to -100% & High Throttle to +100% and bind again.
Do a Learn RC. On the GSU, hold Select Menu & power on. Hold the button until it says release to Learn RC.
Set trim low & throttle low and press the Select Menu button.
Set trim high & throttle low and press the Select Menu button
Set trim high & throttle high and press the Select menu button
File Type: pdf
