RCU Forums - View Single Post - Tornado S30 Pull Start Help
Old 02-22-2016 | 07:59 AM
Troop38
Default Tornado S30 Pull Start Help
Hello Everyone,
So I recently decided to start running my Tornado S30 that I've had for quite awhile now. I cleaned everything before starting and went through the proper procedures. My problem comes from starting the engine via my pull start. It takes about two pulls to get the engine started. But every now and then it seems as though when the engine fires it pulls the chord pretty much out of my hand. i took the pull start apart to inspect it and everything inside seems to be where it should be. The spring is still there. Is it possibly the hex nut that comes off the back of the engine where the pull starts sits? Im not sure what to check when it comes to this. Thanks in advance for any advice.
