RCU Forums - View Single Post - What hex drivers do you use?
Old 02-22-2016 | 03:05 PM
mattster1971's Avatar
mattster1971
I concur, I also like the Dynamite hex drivers, even the less expensive rubber handle drivers work well and if they round out you can grind the tip a bit for a fresh surface. I also have a set of the Duratrax drivers with exchangeble bits and they are great too. Any hex is going to wear over time. Your best to use deep well heads on your screws, will prolong the bit life of the driver.
