Originally Posted by
t6racer
Hi David and George
Well I bit the bullet and bought a Kingteck turbo prop mounting it into my pc21 i will try a 26x14 Beila 3 blade on it where do I get exhaust extensions from can;t believe they don't supply them
Hey t6racer,
Good luck with PC-21. Curious, are you mount that 26" diameter prop on a Skymaster PC-21? The reason for this question, I've been using a 24" diameter prop on my plane, and notice how little clearance there is between the tip of the prop and the ground. So just wondering if prop/ground clearance is going to be a problem.
