RCU Forums - View Single Post - 90 size Kaos
Thread: 90 size Kaos
Old 02-26-2016 | 09:57 AM
RDJeff
Now, onto the Kaos build!
I started with the horizontal stabilizer, standard stick framing. Did I mention how much I like using a magnetic building board setup? It's the greatest thing ever! Anyway, got the 1/4 x 1/2 framing done, sheeted both sides with 3/32 balsa, then weighted it all down with bags of lead shot.
Next, I moved onto gluing in the reinforcements for the elevator halves. The plans call out pine inserts, but I just doubled up 1/4" ply, and glued them in. More lead shot to keep things flat on the board.
Next is the vertical stabilizer and rudder, both are 3/8 balsa sheet from the short kit, each built of several pieces. All glued up and weighted down.
Not bad for an evening's work!
ID:	2149512   Click image for larger version
ID:	2149513   Click image for larger version
ID:	2149514   Click image for larger version
ID:	2149515   Click image for larger version
ID:	2149516   Click image for larger version
ID:	2149517   Click image for larger version
