RCU Forums - View Single Post - EXPOTENTIAL G2
Old 10-21-2003 | 05:02 PM
SeenMCrash
Default RE: EXPOTENTIAL G2
I'm not sure about expo, but I know you can lower the control throw. You must make a copy of the aircraft, and then go into control surfaces. There, select the surface you would like to edit, and lower the numbers in the percentage boxes. (I'm sorry if these instructions aren't perfectly clear, haven't been on in a while). Lower them little by little until you get the desired feel. -Andrew
