Yes a twelve x ten is way to much prop for your Magnum engine. If you have done a proper float installation with the step at a quarter inch behind the actual CG and the wing a few degrees positive to the floats top decks, your airplane will fly fine.
If you are still not happy with the 12x6 then try a 11x7.
John
