RCU Forums - View Single Post - Aileron help!
Old 10-21-2003 | 06:07 PM
Balsa Master's Avatar
Balsa Master
Default RE: Aileron help!
this is why a gap is bad, btw if the gap is 1/8 all the way down ant doesent taper and is clost to the gap in oter wing then tape over else, use some de bonder (from LHS) and re glue (with NEW hinges ) using the pin meathod where you glue after inserting.
