RCU Forums - View Single Post - Pull-Pull cable routing
Old 03-02-2016 | 04:25 PM
Taxus812's Avatar
Taxus812
While that is a good idea (and has me rethinking it) I meant run the cable inside the plastic tube. Making the 5 deg a gradual curve with supports on the tube the entire length. The other idea I had was to use brass tubing to do basically the same thing but it would end when the curve is complete.
