Originally Posted by
wright 971
Hi Rex if you want tyres that look more like the right type Not perfect but they fit Tamiya wheels I Used these
http://www.ebay.co.uk/itm/FOUR-LARGE...IAAOSwWTRW0yY7
shape the treads by spinning them in a drill and sanding a radius on them also remove the side markings on the tyres they are a perfect scale diameter .You will have to search for them took me a while to get enough.
regards pete
Hey !!! Thanks for that source idea ---- those tires look like they could be of use on a lot of builds. I would need more than 4, so I did a Google search for --- LARGE BLACK LEGO TYRES 24X43 --- I found a Lego page that showed a bunch of the tires they make. I gotta investigate exactly what they have. A lot of it could be modified as you suggested. I didn't know Lego made tires, and I also saw some differential type gears that look interesting.
Thanks again !
