RCU Forums - View Single Post - New Member needs advice on PT-40 Trainer build
Old 03-07-2016 | 10:17 AM
JollyPopper's Avatar
JollyPopper
It appears to be cut out of a flat balsa sheet. Go to your local hobby shop (you don't list a location) and buy a sheet of 1/4 inch (looks like) balsa and using the plan as a pattern, cut out a piece that will fit. A couple dollars for the balsa and five minutes cutting it out should cover it.
