I went out early today before I got busy with work to get the inside of the lower cowl assembly glassed with pre-cut sheets to size needed,
After this sets up ( I used extra time), I will then look into cutting the removable lower section away.
Im quite nervous that some of my CA and epoxy may have gotten into areas it wasnt suppose to, but hopefully I had enough monkote in those areas
While I was glassing and clothing the inside bottom cowl for strength , I also tri-stocked both sides of fire wall and glassed the back side of fire wall only with cloth after making sure they were square and being careful to not get epoxy in my blind nut areas.
