RCU Forums - View Single Post - CA Models Passport P-Mix Tip
Old 03-07-2016 | 01:53 PM
toddblose's Avatar
toddblose
My Feedback: (10)
Some info here. Also there should be some info here on RCU just do a search.
http://toddblose.homestead.com/Pass-Port_build2.html
The throws I used were
Aeliron, 25 deg high and 10 deg low rate
Elev 20 deg High and 10 deg low rate
Rudder all you can get on high for stall turns but you will use very little in normal flying. Add SFG's on the wings if they come with it
