Originally Posted by
scrogerio
Do you resolve your problem? I have the same on my JetCat P180rx
The Rx motors can use 3s Li-Po's with the V10 ECU. Janne's V6 couldn't ;-)
If the Rx is doing it its another fault, do you have access to another Rx pump you can plug in and try? There are electronics in the Rx pumps. If not the turbine needs to go back.
Dave
